Most Reliable Plasmas
Discussion in 'Plasma TVs' started by aouieewer, Oct 11, 2004.
  1. aouieewer
    aouieewer
    I'm looking at buying a new plasma for the office. It's main function would be to run a looping powerpoint show for clients. The two I have found are the Pioneer PDP-433CMX and Sony's PFM 42V1/B. Between the two companies, which one is more reliable, less likely to have something go wrong, and last the longest with the best computer resolution? Please help!
  2. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    There are far more experienced members here who will do doubt correct me, but given your requirements, why do you specifically want a plasma? I suspect that a Sharp Aquos 3700 LCD monitor would be a far better bet (or a 45" Titanium Aquos if you really need the size).
    You'll have far less worries about burn-in, far longer life, and they are (as far as I know) far more suited to connection to a PC.
  3. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    No need for correction Sulis - LCD is usually far better suited to the boardroom for all those reasons listed. A more expensive option if you must have 42/43" but if you're just looking for a big-ish display a 30" LCD represents a real bargain. £2k for a good one, £1k for the DABS cheap and cheerful (which will likely be all you need!).
  4. aouieewer
    aouieewer
    I need bigger then a '30 and will probably be using it for other things. Plus, it's not my buck, so I would rather go with bigger and shinnier. so, if you could please help, between the Pioneer and a Sony, which company gives a better product?
  5. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    Pioneer without a doubt, if it HAD to be one of the two.
    But a 37" or 40" LCD will cost maybe 50% more, but still give you twice the lifetime, higher resolution and no screenburn. LCDs also run on less power and are native widescreen resolutions (so your presentations don't look all short and fat!)
  6. aouieewer
    aouieewer
    How do LCD screens do for functions other then computer output, aka, training DVD's and anything else?
  7. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    I don't think LCDs are quite there for the top dedicated Home Cinema installs, I think plasma achieves the nicer picture overall. But for anything less than the ultimate setup the newest generation of LCDs are there with the top plasmas on PQ from PC and from video sources (DVD, Digit TV etc).
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  9. aouieewer
    aouieewer
    Well...I can't get an LCD. The budget has been set and the approval has gone through, so really, the LCD isn't an option. Which brings me to the original question. Which one is better between a Sony and a Pioneer
  10. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Pioneer is the daddy of the plasma world. :)
    S.
