Most Recommended Plasma Screen?
Discussion in 'Plasma TVs' started by TommyB, Jul 17, 2005.
  1. TommyB
    TommyB
    Hi.. im new to these forums.. and also new to plasma screens...
    im thinking of buying a 42" plasma TV... currently ive got Sky + and will be using that as my main viewing source
    im a total amateur when it comes to the suitable specs, what with all the 'HD TV' stuff that people are talking about.
    i want to buy the best possible plasma tv that i can get for £1500 or under.. including sound and the ability to use my Sky + box
    which ones would you recommend?
    thanks!
  2. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,814
    71
    birkenhead
    +73
    well you wont get HD with that budget mate so that narrows it right down and the genral consensus is either panasonic or pioneer.best thing to do is just read the threads and replys (there is a wealth of knowledge on here if you search) and then the most important thing DEMO,DEMO and more DEMO.
    best advice is to read some posts.
  3. ddlooping
    ddlooping
    Oct 7, 2003
    1,413
    Essex
    +27
    Hi all. :)
    Well, I'm not sure how good it is, but Samsung have a High Definition (HD) set for about £1500.
    In any case, follow Silverback's advice and read the numerous threads about the subject , and try and demo as many (well set-up) screens as possible. ;)
  4. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    You need to add £1000 to your budget to get what you're after....
    Pioneer (of course......) comes recommended! :rolleyes: :boring: :spam:
  5. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    13,984
    2
    4
    137
    Garstang, Lancs
    +1,568
    Where abouts are you?
    It's not as easy as you think to get a decent demo.
  6. ash
    ash
    Jun 9, 2005
    11,044
    +383
  7. Korum
    Korum
    Feb 19, 2005
    4,226
    Stockton-on-Tees
    +666
    He never actually said he wanted a HD plasma TV for £1500 just the best possible one for that budget.
    After seeing numerous setups I think you should go for a Panny, IMO they have the best PQ with sky.If you want sound your only panny choice would be the TH-42PE50, you should be able to find one online for around £1500.
  8. Dave
    Dave
    Jul 3, 2005
    11,483
    163
    +3,392
    You could also get a panasonic pwd7 for 1100 quid and just use any pair of speakers to get your sound.
  9. TommyB
    TommyB
    thanks for all the help!
    ive just been to currys.. and saw a SAGEM 45" DLP rear projection TV...priced at 1699, a bit out of my budget.. but i dont mind adding a little extra if its worth it.. and it was HD ready aswell... would you recommend this over some of the plasma's that have been mentioned in this thread?
  10. dilsher
    dilsher
    YesTommy I would.
  11. clarky78
    clarky78
    Nov 8, 2004
    1,830
    Nottingham
    +37
  12. ash
    ash
    Jun 9, 2005
    11,044
    +383
    :oops:
    Sorry, TommyB, are you a member of Makro?
  13. TommyB
    TommyB
    no ashmufc im not.. but i really want to be.. how do i become a member cuz i heard that you can get real cheap stuff there
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the most reconmended plasma has to be the SD panasonic 7 series panel aka PWD7 and PW7..............odd isnt it, a none TV, none HD ready screen is the most reconemended and i would think the most widely owned by far.............(on this forum if not nationally)
  15. manorlodge
    manorlodge
    Jul 23, 2004
    27
    4
  16. TommyB
    TommyB
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    go demo to make sure you dont suffer from "rainbows" and as long as you dont want to wall mount a DLP should be fine different beast to a plasma tho being projection based.....
  18. TommyB
    TommyB
    thanks for that hornydragon... but seeing as im spending 1699.. do you think i should go for another plasma that will be just as good in quality?.. and if so which one?...because the DLP is HD ready..and plasma's with that same spec tend to be over 2000... what you think?
  19. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    for plasma its got to be samsung for HD Ready at that price so you get to choose DLP or Plasma (samsung) you dont get any plasma choice at that money not much DLP either its not much budget for HD mate regardless of technology
  20. TonyA
    TonyA
    Oct 16, 2004
    2,765
    London
    +217
    Be VERY carelful with DLP!
    I had my heart set on a DLP set - then I got some "proper" demos of the majority of the available DLP sets, and discovered that after all the research I'd put into it, that I suffered from the "rainbow effect" (a peculiarity of DLP that causes colour flashes on the screen when your eyes move from one part of the screen to another - some people see it - others don't).
    I would check if you're buying it for the family, to ensure all family members get to demo your selected set, to ensure they don't suffer from "rainbows", otherwise some family members may not thank you for it, due to eye strain, headaches, and seeing colour flashes all of the time.
    I'm glad this happened to me really, as it caused me to re-look at plasma, and I ended up purchasing a Panny PV500, and I'm over the moon with it.
    To be honest, it might be better to wait to see if you can increase your budget by a few hundred pounds, which will give you a much wider choice, in both DLP and Plasma.
  21. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    I would second that having just bought the Samsung SP46L6HX DLP. Unfortunately like me you can demo as much as you can in shops but it's not until you get one running in your home environment until you really start to notice this rainbow effect. Just make sure that you coose a retailer with a good returns policy.
  22. rudy
    rudy
    Jan 2, 2005
    499
    Sagem is nice but the anti reflective coating gives 'shimmery' whites. The new model 56" has been improved in this respect
    If you go Plasma
    If you dont't need HD go for Panny pw7
    If you do want HD look at new Samsung
    And don't buy a Tiny
  23. alpina
    alpina
    what does the "D" stand for or should i ask what makes the "D" version different to the model without the "D"?
    regards,
    julie
  24. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    13,984
    2
    4
    137
    Garstang, Lancs
    +1,568
  25. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the PWD is a commercial model PW consumer there are actually some big difference between consumer and commercial 7 series (PW7 has G6 phosphur and G7 electronics PWD7 has G7 phoshpur and G7 electronincs) big difference on poaper, very little in the flesh but i would always go for commercial panny screens
  26. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    the D means it's a commercial model...and there is a thread that lists teh differences somewhere....just search for pw7 pwd7 should find it....i have one of each and the practical differences are neglible.....the pwd7 has 2 drivers and therefore more PIP capabilities..it also has 7 series glass as opposed to 6 series in the pw7.....but they both look and perform exactly the same to my eye.
  27. pwood
    pwood
    Dec 6, 2003
    2,479
    Central Scotland
    +136
    GOOD advice. Also bear in mind the viewing angle issue as well. Rainbow effects are very hard to see in brightly lit shops which are far removed from the average living room environment.
