more xbox high def questions.
Discussion in 'Xbox Forums' started by watchinthewheel, Apr 25, 2005.
  1. watchinthewheel
    watchinthewheel
    hi, im trying to get my xbox to run on my crt pc monitor. i have just ordered an x2vga adaptor and so wanna find out what i have to do while i wait for it to arrive. i have a pal xbox but its chipped so i heard it can be forced to ntsc mode. how can i do this do i have to download an app or something? i have an xecutor 2 chip if thats important.
    thanks for any help.
  2. dred
    dred
    Mar 26, 2002
    289
    +39
    You need the 'enigmah video selector' which is included in slaYers, I think you can also switch to NTSC from the avalaunch dash too if you have that?
    Then when you connect the X2VGA (or component cable) you get the extra HD options in the video settings of the MS dashboard, just enable all options which your monitor supports and you should be good to enjoy HD gaming.
    You can also toggle the MS dash between 480p and 480i by pressing both triggers while pushing in both thumb sticks.
