MORE WHARFEDALE PROBLEMS - GLADIATOR!!!
Discussion in 'Movie Forum' started by ROGER B, Nov 20, 2000.
  1. ROGER B
    ROGER B
    My wharfedale player wont play the extras disc of Gladiator, the film works fine but disc 2 just locks up the player.
    Ive tried 2 different copies but it just does the same, has anyone had the same problem with the r1 copy.
    cheers
    Roj
  2. Martin McCaffrey
    Martin McCaffrey
    I tried two copies as well and my mate tried it as well. Both of us tried region 2 copies and experienced total lock up, anyone got a fix???
  3. Guest
    I have a Grundig GDV210A which also won't play this disc. There are other players that won't. the LG the Proline and there may be others. Got no joy from Columbia- Tristar, all I got was, well these are budget players! I persolnally think that if a disc is causing problems with many players, whether they are budget or not, it should be pulled, and re-programmed!
