more than 4 satellite feeds?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by cj, Sep 9, 2003.
  1. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Is it possible to have more than 4 feeds from a single Sky digital dish, or do I need to put up another?
  2. GETanner
    GETanner
    Mar 11, 2002
    572
    +76
    Sure.
    You will need either a Quad LNB or Quattro LNB and a distribution switch box.
    Have a look at this page http://www.brymar.co.uk/acatalog/Satellite_Distribution_Soloutions.html
    or http://www.sateuropa.co.uk/overview.asp?catid=1&subcat=11
    This lists the type of equipment you will need. Be carefull that you get the right combination though. Distribution boxes are designed for either a quad or quattro LNB (The difference being where the Hi/Lo V/H feed is controlled, with a quad LNB the distribution box controls the LNB. With a Quattro LNB, the LNB controls the Hi/Lo V/H feed).
    Guy
  3. DaveP
    DaveP
    Alternatively, use a 90cm dish with twin offset quad LNB's probably cheaper!
    Dave
  4. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Hmmmm just emailed Brymar and they suggested either installing another dish (+ quad LNB) or
    "Your only other way is to use a standard 60cm (#25) dish witha 8 output
    lnb(#129) on - which will obviously need installing
    Regards"
    An 8 output LNB?
  5. DaveP
    DaveP
    I still think my idea is better! (well I would, wouldn't I). I often wonder about quotes from professionala, at the end of the day they are in it to make money and won't necessarily suggest the cheapest solution.
    BTW, I know a quad on an off-set works OK as that's how I had mine set up when I had three sats from one dish.
    Dave
