More than 1 ipod issue...
Discussion in 'Headphones, Earphones & Portable Music' started by Les E, Mar 17, 2005.
Tags:
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    This must of been in a previous thread, but I have a 2 ipods (well, the wife has a full size and I've got a mini!) and we have one G5 mac with itunes...what are my options??
    Surely, apple must of thought there may be more than one person in a household with an ipod that doesn't share the other persons taste in music?
    So how can I set up a seperate source library that won't upload each others music?
    One option would be to unselect the other users tracks...but the wife has hundreds!!!
    I am in some desperate need of some help here guys!!! :lease:
  2. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
    not sure, but if you can't find an answer here, check out ipodhacks or ipodlounge - this has been discussed to death there
  3. mick's cat
    mick's cat
    The best (and Apple suggested) solution is probably just to set up another user account so you have one each (System Preferences - Accounts). Then each user's iTunes is separate, although you can use the same folder of music. With Fast User Switching this is a doddle to work with and is pretty seamless.
    Another way is to use a third-party utility (there's about three around I believe) that allow you to switch Libraries on the one user account. From what I've heard, these aren't perfect.
