More than 1 HDMI device into single HDMI socket on TV?
Discussion in 'General TV Discussions Forum' started by cahonis, Nov 7, 2005.
  1. cahonis
    cahonis
    Mar 24, 2005
    4
    I only have a single HDMI interface on my TV and was wondering how/if it was possible to connect 2 or more HDMI devices into this interface?
    Only one of the connected devices would be on at any one time so I was wondering if there is such a thing as a splitter for HDMI or is it the case that I will only be able to connect one HDMI device to my TV?
    Thank you :)
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
  3. TheDoctor
    TheDoctor
    Aug 31, 2004
    389
    28
    +42
    Hi Dutch
    I beleive the Gefen HDMI switchers (2 to 1) are going for £150 at Maplins. If you want something that looks a lot nicer and not out of place, then I suggest the Dtrovision range:
    http://www.dtrovision.com/hds_41r.htm
    Doc
  4. cahonis
    cahonis
    Mar 24, 2005
    4
    Thanks for your replies, much appreciated :)
  5. DanDT
    DanDT
    Aug 31, 2005
    1,169
    63
    London
    +144
    Flippin heck!!
    I thought HDMI switchers were sort of like SCART multi-plugs, the ones you buy at Dixons for 10 quid!!
    Bloody hell those things are huge and expensive, why is that?!
  6. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Because of the HDMI Receiver and Transmitter chips in them? Digital signal switching is complex and needs microchips on PCBs, whereas analogue signal switching (like scart) can use a few resistors and wires.
    StooMonster
  7. TheDoctor
    TheDoctor
    Aug 31, 2004
    389
    28
    +42
    Hi DanDT
    If only............they are like mini amps that have to be able to accept/distribute high-resolution digital video/audio without loss. Also HDCP compliance has to be catered for.
    Doc
  8. Kevo
    Kevo
    Aug 23, 2001
    5,515
    Manchester
    +193
    So I guess it's back to the old '1 x RGB SCART' problem with new TVs then?
    If it's even more expensive to do, then multiple HDMIs on TVs will be even more rare than multiple RGB SCARTS.
    Here we go again :rolleyes:
    I've just purchased a Pan 42PV500 which comes with 2 x RGB SCARTS :smashin: (about 10 years too late!) and only one HDMI :thumbsdow
    Now at the moment I only have one source to feed the one HDMI (a PC).
    But not too far away is....DVD with scaler, Xbox 360, PS3, Sky or Cable HDTV(?).
  9. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +6
    The lack of HDMI sockets will be a relativly short lived problem. Unlike RGB Scart (or component when released in the US) HDMI is a global concept. HDMI sockets are starting to appear all over the place. Already you can buy a reasonable price AV amp with HDMI switching. Hopefully we will also see kit with HDMI daisy-chain capability too.
    With such a small form-factor to the plug we may see products with ooddles of them, rather than the space hungry French inspired Euro-monkey scart.
    Not that I like HDMI though - heavy leads fall out of vertical sockets, just like some scarts did... progress! Now why does my DVI socket have little thumb screws....
