..more sony nw-hd3 recording q's??
Discussion in 'Headphones, Earphones & Portable Music' started by kyussone, May 4, 2005.
  1. kyussone
    kyussone
    hi guys, thanks to you lot i bought one and its f~kin great, so i was wondering if anybody here could help me with some questions? i read through the other threads and didn't see any related topics, so here goes..
    1/ can you record from any other sources to sonic stage/hd3? ie i got lots of vinyl and md's i want to put on the hd3,so is there some kind of analogue/usb adaptor etc available? what about editing/shortening tracks?
    2/some cd's have stupidly low volume output, while others are really high, i don't suppose there's a way to set a recording level? or are there any tips for this problem? at the moment it really annoys me that my hd3 vol goes up and down according to some cd's!
    thanks in advance!
  2. watchinthewheel
    watchinthewheel
    1) you will have to get the tracks into a ,format the hd3 can recognise (atrac/mp3) if you search using google for vinyl to mp3 you should be able to do that. the mini disks are i think in atrac anyway so no problems there.
    2)use a program like mp3 normaliser to get the same volume over a lot of albums.heres the download
    hope that helps mate ;)
  3. SteveG
    SteveG
    Jan 14, 2003
    1,024
    London, UK
    +87
    The difference in volume between tracks has been bothering me too, so I stopped using shuffle in the end. Is there any downside to using this software, such as loss of quality in the mp3, or does it really just alter the volume and nothing else? I know there's a 10 file trial but just wanted to get some opinions before coughing up $20.
    Pity you cant alter the volume in SS as you can in iTunes.
  4. kyussone
    kyussone
    thanks for the info, much appreciated, excuse my lack of teck savi-ness, the SS library i have build up is in atrac+ format right? how does it work if the software is for mp3? do i need to convert it from the atrac?
    :suicide:
  5. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,436
    +6,222
    latest ver of SS is 3.1 which has built in MP3 encoder. Just make sure you change settings so SS doesn't auto convert format when transsferring to a DAP or a CD
