More Sony DAV DZ260 woes--please can someone help?
Discussion in 'Home Cinema Buying & Building' started by kitbits, Feb 7, 2009.
  1. kitbits
    kitbits
    Feb 6, 2009
    Hi, we're having problems connecting all of our components to the Sony DAV DZ260, which we purchased about a month ago.
    We can watch films on it, no prob, but we want to have the same sound set up for Sky (just bog-standard) and our multi-region DVD player, which is old, but hey, it's multi-region, unlike the over-priced one-region Sony. I loathe to shell out more money to make the Sony multi-region...
    Anyway, this is what we have:
    Sharp LCD tv
    Sky (regular, not plus or HD)
    Acoustic Solutions DVD551 multi-region player
    DAV DZ260
    Also, we have a Sharp blu-ray player, but that's optional...we don't have any blu-ray dvds & the Sony plays what we have from region 2 just fine.
    Please let me know what other info you need...thanks!
  2. kitbits
    kitbits
    Feb 6, 2009
    :( we have tried...anybody? please??
  3. davepuma
    davepuma
    Jun 24, 2004
    17,541
    +3,506
    Going by the specs here you might be able to connect up either a SCART cable (omitting the yellow video cable) to the input on the Sony and receive audio in that way. Another option would be a composite video to SCART cable (omitting the yellow video cable from and only connecting the red/white audio cables) or analogue audio to a SCART adaptor (most are switchable for input/output) but without knowing the details of the TV, I don't even know if it can output audio over its SCART connection. Check the manual (or post a link to an online manual and someone can take a look).
    I'm afraid that all-in-one home cinema systems are not designed for multiple sources and if you want surround sound from your digital sources i.e. multi-region dvd player and/or bluray player, then you're going to need some form of switch e.g. 3 way manual optical switch (or toslink splitter) to share the single digital input. I doubt I would find an online manual for the Acoustic Solutions player, so post back with the available connections (it saves us trawling the net looking for them. Not so much a problem with mainstream brands but the lesser known brands are harder to find).
  4. kitbits
    kitbits
    Feb 6, 2009
    Hi, davepuma :) Thank you so much for your reply. We'll try it over the next few days (busy work week!) & I'll let you know how we get on & will also post back with the connections. Tried to find the stupid manual--found all the others, but not that...typical!
    Thanks again!
    :D
  5. kitbits
    kitbits
    Feb 6, 2009
    Hi davepuma...please accept my apologies for not getting back to this sooner...other things in life got in the way, as happens! anyway...here are photos of the inputs for the old multi-region DVD. haven't tried any of your suggestions yet because we wanted to show you the pics first. Many thanks for all of your advice!
    links to photos:
    2009_0314Misc0016.jpg picture by missmoonpie - Photobucket
    2009_0314Misc0015.jpg picture by missmoonpie - Photobucket
  6. davepuma
    davepuma
    Jun 24, 2004
    17,541
    +3,506
    Use an optical cable and if you want to connect more than one optical device, you'll need the 3 way manual optical switch. See tvcables or maplins etc.
  7. kitbits
    kitbits
    Feb 6, 2009
    thank you davepuma! i'll let you know how we get on :thumbsup:
  8. kitbits
    kitbits
    Feb 6, 2009
    worked like a charm & all for under £20!
    many thanks, davepuma!!:clap:
