More Ram for Xbox?
Discussion in 'Xbox Forums' started by scottbown, Mar 20, 2005.
  1. scottbown
    scottbown
    Feb 18, 2005
    101
    19
    Bristol
    Does anyone know how to increase the ram on the xbox? It's currently 128MB? What type is it? where to get it from? How to install?
    I'd like to increase the RAM to allow me to play more of the larger MAME roms as anything above 20MB causes Mame-X to Crash :(
    Thanks,
    Scott
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    It normally has 64mb. It is very hard and expensive to do a ram upgrade on the xbox. You will definitely not be able to do it yourself and I believe the chips required are also very hard/expensive to come by.
    The only place I know that does it is in the USA and they charge $60 --- http://www.upgrade123.com/catalog/product_info.php?products_id=85
  3. scottbown
    scottbown
    Feb 18, 2005
    101
    19
    Bristol
    Cheers explicitlyrics,
    Yeah, i thought it was 64MB. doh!, Sending it to the US is a little OTT. I'll keep my eyes peeled for a uk modder who can do it.
    Maybe it's the version of Mame-X i'm using? (beta5.) Does anyone if the later versions of mame-x or other xbox mame emulators cope with the lack of ram issue?
    And if so where to get hold of them?
    Thanks,
    Scott
  4. Goone
    Goone
    Oct 21, 2003
    118
    uk,london
    Try getting hold of Mameox,it uses virtual memory to run the larger roms,just google it for info
