More PW6 connections questions......sorry!
Discussion in 'Plasma TVs' started by taxman, Sep 6, 2004.
  1. taxman
    taxman
    Sep 5, 2004
    4
    Right I have settled on buying the PW6. I just now need to understand what the best connection set up is. I have a Sony DAV-S550 and a NTL digital cable box that I want to connect. I will also occasionally connect my PC to the PW6. From what I understand the potential options are:
    1) Connect Sony DAV-S550 direct to the PW6 via a component terminal board and connect the NTL digital cable box via the JS RGB-VGA converter.
    2) Connect both the Sony DAV-S550 and the NTL digital cable box via a Quintro box to JS RGB-VGA converter which then feeds into the PW6.
    Please can I have thoughts on whether option 1 or 2 above is the best route to follow. Or are there other options that I should also consider???
    thanks
    R
