More Powerstrip woes !
Discussion in 'LCD & LED LCD TVs Forum' started by richjthorpe, Feb 23, 2005.
Tags:
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    I've finally got my laptop connected to the 32GA3 in 1024x768 mode. Hurrah ! I hbad to flick a setting in the BIOS in order to view in this disaply, otherwise it was 800x600.
    Anyway, I've downloaded Powerstrip and copied Reddoms settings and pasted them into the Advance Timings clipboard. A popup came up saying that 'The custom timings are not appropriate for the current resolution' and to 'Select the Timings from the "Custom Resolution" Dialog box'.
    Only thing is, the "Custom Resolutions" button is greyed out.
    The max res the graphics card can kick out is 1600x1200, should it be able to display WXGA ?
    Thanks all,
    Richie.
  2. Vorix
    Vorix
    Feb 2, 2005
    365
    Bracknell
    +14
    Have a look on the FAQ's on the Powerstrip web site at http://www.entechtaiwan.com/ (doesn't seem to be available at the moment) or I found some interesting stuff via Google at http://www.ramelectronics.net/html/powerstrip.html.
    Your graphics card must be capable of supporting custom resolutions for Powerstrip to do its stuff:
    What graphics chip have you got in the laptop?
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    B*gger. The graphics are only a Trident Cyberblade chip so I doubt they would accept custom resolutions.
    Nevermind. At least I've got 1024x768, at one point I thought I could only get 800x600 !
    Thanks Vorix,
    Richie.
  4. mwpbakker
    mwpbakker
    Powerstrip will only accept custom resolutions when registered. The trial version doen not accept custom resolutions.
    A fellow 32GA3E owner at 1360x768 with powerstrip and HTPC.
  5. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Are you sure ? Has anyone got a registered copy so I can test it ? Don't particulatly want to pay out for something that doesn't work. I don't need to use it at the moment as it is.
    Richie.
  6. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    I'm not sure. I've used it for custom resolutions without registering.
    I am pretty sure it wont work for you though Richie, on two counts. First, you're using an unsupported chipset. And two, IIRC, most laptop chipsets have different drivers - so even with an ATI Radeon in a laptop, powerstrip still wont work (doesn't on my IBM laptop).
  7. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Nevermind.
    Anyone selling a P2.4 for about £50 ? :D
    Richie.
