More newbie help part 3
Discussion in 'Home Cinema Speakers' started by Darkly, Dec 6, 2001.
  1. Darkly
    Darkly
    Nov 23, 2001
    29
    3
    Ok, I'll try and make this as brief as poss ;)
    I'm going to buy the Tosh 42 RPTV tele, which I think is pretty much exactly the same as the older 40 from what I've read on the forum here from owners (though not seen a review yet).
    I can't afford an amp/speaker setup yet, not with the outlay on the TV and DVD player, so will have to make do with TV sound, but read in the HCC Tosh 40 review that they recommended hooking an extra 2 front speakers up to it, along with a sub, as there are line outs for these on the tele (presumably then using the built in TV speakers as a centre channel).
    Has anybody done this, and if so what is a good, not too expensive pair of speakers and sub to do this with. Any feedback most welcome :)
