More money on centre or rears
Discussion in 'Home Cinema Speakers' started by scouse, Feb 15, 2003.
  1. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    Should I spend more money on a centre speaker or on a pair of rears? My setup is as follows:
    Yammie A2
    Wharfedale Valdus 400's as fronts
    ....need advice on centre and rears for a budget of £150...
    thanks
  2. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    I'd spend more on the center, the center is possibly more important than the front l&r for films as a lot of the dialogue is anchored to the center.
    Try and get a center speaker to match your existing fronts, and don't worry as much about matching the rears with the fronts.
  3. nathan_silly
    nathan_silly
    Centre. The most important channel, you need a high quality centre. Try and find the matching centre to your L/Rls (Wharfdale Valdus)
  4. nathan_silly
    nathan_silly
    copy cat! copy cat!
  5. bob007
    bob007
    Out of the two options you have given I would go for a centre, the Wharfdale Valdus centre can be picked up quite cheap. To contact Wharfedale UK, telephone 0845 458 0011, they should be able to help with a local dealer.
    IMO the most important channel in a full 5.1/6.1 system is the sub. ;)
    I ain't no copy cat. :)
  6. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    Indeed.
    Sub, center, fronts, rears. In that order.
  7. petrolhead
    petrolhead
    Mar 29, 2002
    4,788
    87
    Newcastle
    +116
    I would second that
  8. stranger
    stranger
    the valdus centre is often advertised really cheap by r/sounds and hyperfi in what-hifi mag.
