More help with Fleetwood mack
Discussion in 'Music & Music Streaming Services' started by Gadjet, May 11, 2003.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Sorry to keep on but I need advice on this dvd-audio. There is no difference in the change between the sound when I choose 2 channel stereo or 5.1 sound. also there is no change on the amp which says Dolby P2 music on both settings. It worked great on the previous audio -corrs before it was nicked. My amp is Pioneer Vsa-10 and 747 amp. Is there anyone there with this disc that plays dolby digital when selected on .
    Phill
  2. museumsteve
    museumsteve
    Jan 28, 2001
    7,528
    3
    Nth Hampshire
    +1,007
    which album is it.?
  3. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    The album is their latest called say you will. The choice of sound is Dolby Digital or advanced stereo. When I choose either it still says on the amp D P11 music.,
    Phil
  4. museumsteve
    museumsteve
    Jan 28, 2001
    7,528
    3
    Nth Hampshire
    +1,007
    so is the DVD player new.?? (as in a replacement) If os have you been in to settings and set-up again. I've looked at my manual for my Pioneer 939-A (I guess they are fairly similar) and you have to tell my player to acknowledge the 5.1 analogue connectiosn otherwise everything will be directed to optical. Might be worth a look anyway, otehr than that cant really help.
  5. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    I have gone through all the manuals on the 747 and the amp. The sound works when I put the amp on multi-channel which is what I use for SACD. I have got one of them celion dione, works great. It must be that this fleetwood mac one must not work on DD?
    Cheers,
    phill
