More connection help required
Discussion in 'AV Receivers & Amplifiers' started by harveydean_uk, Nov 12, 2003.
  1. harveydean_uk
    harveydean_uk
    Which is the better connection from my DVDR to my AV Receiver
    Digital or Coax?
    ALSO - Is component or Scart better to connect the DVDR to the TV?
    Thanks in advance
    Dean
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,135
    2
    2
    137
    Airdrie, Scotland
    +986
    I do not believe there is really any difference between coax and digital (I believe you really mean optical here) - I use coax myself, but do not believe I could tell the difference if I had an optical connection.
    There is no doubt that component is a better conection for video than scart (RGB), provided your TV can accept such an input, which not too many can.
    Best of luck.
