Mordaunt short
Discussion in 'Home Cinema Speakers' started by alan thompson, Apr 18, 2003.
  1. alan thompson
    alan thompson
    I don't know wether to buy Mordaunt short 902 standmounts or the 904 floor mounts, I have a 905 centre speaker.
    Is the signature model much better than the standard.
    Any help please
  2. YtramC
    YtramC
    Personally I'm not sure which ones are better, but would recommend you hear both on a demo so you can compare back to back.
    Marty
  3. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
    I use the 902s for rears, excellent imho.
    Im not a techhead so dont really know alot about why, but I just listen and they are great. Well worth the 200ukp at Richers. I wasnt gonna buy them but agreed to check them out, rest is history.
    I have the ms905c too. But I guess the best way again is to hear both and make your choice. Dunno where you get them from but ask to test them at HOME. Richers will normally let you do this as I have done lots of times in the past.
    regards
  4. Photo
    Don't forget to try the 908s too, they are IMHO very nice. :)
  5. Killcrazy
    Killcrazy
    I've been using the new 914 models with the bigger cabinets and driver than the 904 with the 905c centre and the blend is basically semless across the fronts.
