mordaunt short sub connection problem
Discussion in 'Subwoofers' started by Omar78, Dec 23, 2003.
  1. Omar78
    Omar78
    Dec 21, 2003
    46
    i purchased the mordaunt short premier speaker kit today.. along with a yam rxv340 receiver..
    i have connected all 5 speakers to the yam but when i came to connect the sub to the receiver with the supplied cable.. i got stuck. theres no where on the sub for me to connect the cable. its just a standard subwoofer cable.
    can someone please help me as i am a complete newbie..
  2. Grimley
    Grimley
    Sep 19, 2003
    963
    4
    2
    47
    Deepest, Darkest Essex, so BEWARE!
    +157
    If its a standard Sub cable it should be phono to phono cable so it should go in the line in or low level input connection on the sub.
    HTH
  3. Omar78
    Omar78
    Dec 21, 2003
    46
    nah.. i need 1 phono to 2 phonos.. 1 phono from the amp.. then on the sub its 2 phonos left and right...
    iv just tried a standard cable and it worked.. but i think i need to get a better quality cable.. as the one iv tested it on was only £2 from maplins..
    iv just had another problem.. in the lotr2 the marsh scene.. when the dragon came.. the system just shut itself down.. when powered back on it said "check cables.." not sure what this means..
  4. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    no you only need two phonos on the sub when inputing stereo sounds. if you are using a suround sound arm rvx340 you will only need a phono - phono(LFE is mono) and plug it in to either left or right.
    Some sub makers recomend using a y spliter and running a phono to both the left and the right inputs but i can't see it making a difference in your system
  5. Omar78
    Omar78
    Dec 21, 2003
    46
    oh right.. well im thinking of buying a small y slipper from maplins tomorrow.. its only £4 just in case :)
