Mordaunt-Short Premier vs Premier Plus
Discussion in 'Home Cinema Speakers' started by Pword, Jun 16, 2005.
  1. Pword
    Pword
    There is a big price difference between these two packages, does anyone know the difference between them and do you think the difference is justified?
  2. rockhopper
    rockhopper
    May 24, 2005
    81
    hi, the plus has a far superior subwoofer, making the whole setup sound better. The satellites are identical, its just the sub. If you're not sure whether to spend the extra on the +, buy the standard Premiere first. If you're happy with it keep it, if not sell the MS308 sub and upgrade to the 309. This 'could' actually save you money :)
  3. Pword
    Pword
    thanks for the response and the good idea.
  4. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    i find the 308 to be pretty dam good for movies, but for music i leave it off, it just doesnt have the detail my floorstanders have.
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,664
    If you have a decent pair of floorstanders (or even good standmounts on decent stands) I'd turn the sub off for music irrespective of what it is.
  6. Pword
    Pword
    Is there a difference between speaker stands? The MS stands for the premier cost £80 a pair, which is a bit steep when the whole system only costs £250.
    Can you recomend any other stands that could be used?
  7. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,664
    Alphason's AD100 fits fine but I'd really use the MS wall mount we designed for them if you can.
