Mordaunt Short Prem Plus and 80hz crossover
Discussion in 'Home Cinema Speakers' started by Gatekeeper, Jun 18, 2004.
  1. Gatekeeper
    Gatekeeper
    will the Mordaunt Short Prem Plus speaker system work ok with a denon3801 amp with a fixed crossover of 80hz and how to set them
    cheers
  2. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
    Best bet is ask someone like tons of fun or rozzar mate
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,854
    2
    +3,227
    80hz will be fine- anything between 80-100hz is perfectly ameniable to the Premiere (or indeed most other sub/sat packages). The 300 series speakers finally roll off at about 70hz.
  4. Gatekeeper
    Gatekeeper
    thanks Tons
    just what i wanted to hear :)
  5. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
    Cheers tons let you off taking so long thanks to the sub review!
  6. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,854
    2
    +3,227
    If you remember that I don't often go online at weekends and make it into the office at 9.20am, I'll think you'll find that was pretty swift ;).
