Mordaunt Short Notch Filter
Discussion in 'Subwoofers' started by mr. shr, Aug 25, 2004.
  1. mr. shr
    mr. shr
    Jul 26, 2004
    431
    +6
    I'm currently using a MS309. Can anyone tell me what I should do with the notch filter? It's currently switched off, but I'd like to experiment with it to see if it improves things.
    What procedure should I follow? The 309 doesn't come with a set up CD (I believe that's only with the 909)
    shr
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,849
    2
    +3,222
    It is meant to :blush:. PM me with a postal address and you can have a disc. There is also a better explanation in the manual you can print off the website. Broadly speaking, studying the 309's output from the CD on an SPL meter will probably find a peak that can be ironed out by setting the notch filter accordingly.
