Mordaunt-short MS10
Discussion in 'Home Cinema Speakers' started by un4giv3n, Aug 11, 2004.
  1. un4giv3n
    un4giv3n
    I have been given a set of mordaunt-short ms10 speakers and am having difficulty finding suitable cable/connectors to attach to my amp, the speakers each have 2 ports on the back of them that look like they could house 1/4 inch jacks and the amp has 2 bare wire connection ports for each speaker, any suggestion on which cable i need and best place to get it?
    cheers in advance
    un4giv3n
  2. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Hello and welcome to the forum.The speakers will take any speaker cable ,if you unscrew the red and black thumb screws there will be a hole which goes through the terminals that will take bare wire.Or you could use banana plugs which will plug into the speakers.
    You could get your cable from a number of places ,Maplins the local hifi shop It really depends on how much you want to spend ,just don't go for cheap thin wire.
