mordaunt short help
Discussion in 'Home Cinema Speakers' started by clancol, Nov 13, 2003.
  1. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    i currently have the MS 903's as the rears on a 5.1 set up with the marantz sr5300
    i am going to add two other rear speakers and wire them in series for 6.1
    my question is aimed at the MS guy that lurks on these forums.
    would the sound be improved if i got the 503's and used them as ther rear sides and wired the 903's as the center rear.
    Would they match?
    How much improvment if any?
    How much do they cost?
    is it worth it?
    my room is 3.5 by 2.9 meters. i have two arm chairs that sit about 2.5ft from the rears.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    I assume you mean the 506 dipole? They will certainly produce a bigger sound than the 903- although I warn you that they're huge (the main reason why I traded down from a THX pack when I bought my own house). If performance overides any concerns over decor, then they will improve the performance of the system. I don't neccesarily recommend using 2x903's in series on the back of a 5300 as both speakers are 4ohms nominal. Trading them in and buying a 304, 905, 504 depending on budget would be a better bet for sound/ amp longevity.
  3. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    so if i were to keep the 903's 4 the sides what should i use for the rear another 905c mabey some small bookshelfs.
    or one 903
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    If you have the means to mount it (I would suggest www.omnimount.com ) a 905 is the best bet (if of course you can come to terms with owning an Avant version ;) ) but I personally use a 304 as my centre rear as it wall mounts much more easily. Buying a single 304 to go for 6.1 would be the cheapest and simplest option that would offer a good improvement- especially as the mids and tweeters would be identical across the rear span (assuming you keep the 903's).
  5. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    what about a single 903
    how much are the 506's
  6. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    Would be a bit too diffused- I think the idea of the centre rear is that it should be a monopole.
    506 (pair) is £480
  7. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    dam that a lot
    sorry about all the questions
    what about a pair of 302's run in seriel or would that be the same as the 903 regarding impodence
    that way id have the second rear 4 when i update my amp
