Mordaunt short Genie sub help required.
Discussion in 'Subwoofers' started by chaka7862, Dec 9, 2004.
  1. chaka7862
    chaka7862
    Hi guys, :)
    After reading many reviews I have got myself a new Genie system, but I have a problem. I want to use a dedicated lead from my Yamaha AX750Se amp, I have the lead and the sub is going to be 3 metres from the amp, but the problem is that there are only RCA inputs on the sub and no dedicated input for 1 lead, what are my options? :lease:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    The input on the sub will be of the RCA variety and whilst most subs only have the one input some do have two. If there is nothing in the manual to the contrary either one will do
  3. Jamesv
    Jamesv
    Its sounds as if you need to reread the sub installation instructions my friend. Cant remember from memory but the dedicated lead plugs into one of the sub sockets. Cant remember if its the left or right. I will check when I get home tonight and post back.
  4. bbasra
    bbasra
    Sep 15, 2004
    1,622
    48
    Hounslow
    +41
    Plug it into the Left one.
  5. Santy
    Santy
    it is definately the left one, 'standard' (expensive) phono cable will do the trick...
  6. Ragefire
    Ragefire
    Apr 25, 2005
    +4
    Is it worth purchasing a splitter? Will it make an iota of difference?
  7. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,134
    2
    +3,581
    It increases the sensitivity of the Auto On but otherwise no difference.
    Ed
  8. Ragefire
    Ragefire
    Apr 25, 2005
    +4
    Thanks!
