Mordaunt-Short Genie or Kef 2005
Discussion in 'Home Cinema Speakers' started by ctf, May 12, 2005.
  1. ctf
    ctf
    I have just purchased a Harman Kardon AVR 430 and am looking at the above speakers mainly for use with movies. I can get the kef £200 cheaper. Is it worth spending the extra on the Mordaunt? The room I will be using them in is 8m x 7m x 3.8high but i will be placing speakers in front half. Any advice appreciated.
  2. richard76
    richard76
    go for genie...the money you spent will be worthwhile.
  3. bbasra
    bbasra
    Sep 15, 2004
    1,663
    48
    Hounslow
    +43
    Definely the Genies, there is already a Kef Egg VS MS Genie on this forum... Use the search function.
    .....I have even heard both of them side my side.......Genies are better.
    However, also look at the Mission M-Cube!
