Mordaunt Short Genie 409W Subwoofer Auto Power
Discussion in 'Subwoofers' started by bbasra, Nov 30, 2004.
  1. bbasra
    bbasra
    Sep 15, 2004
    1,600
    48
    Hounslow
    +34
    Hi.
    I cannot get the auto feature on the 409W digital subwoofer to work.
    When i set the 'Auto Feature' to the 'On' position (Down Position), the subwoofer will always stay on (the blue led on the sub is lit) even if the Denon Reciever is swithed off. Even if the Denon Reciever has been swtiched off over night, the blue led is still lit.
    When i set the 'Auto Feature' to the 'Off' position (UP Position), the subwoofer will turn off after a while or so, (the blue led on the sub is off), however, when i power on the Denon Reciever the sub will not power on untill i switch the 'Auto Feature' back to the 'On' position (Down Position).
    Please Help. I don't like leaving things on for no reason when it is not being used.
    Thanks In Advance.
  2. MS-Yam
    MS-Yam
    Aug 12, 2004
    235
    16
    Sorry if this sounds obvious but my ms308 has three positions. To use the auto mode I set in in the middle.
    I dont know whether yours is the same.
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,942
    2
    +3,309
    Auto- On/Off generally works best with both inputs connected at the same time but I think I've just spoken to you about this so you already know that I advocate leaving it on all the time ;).
