Having read this forum for a couple of months, I am still at the early stage of deciding on a system, though it will most likely consist of a Panny 7, Yamaha 750, Sony 955.
As the room I am converting to a mini-loung/cinema is not very big (3.8m x 2.5m), I am currently undecided between the MS Avant Premier Plus system or using MS 902 (x4), MS304 centre and MS309 subwoofer.
The 902s are physically bigger and should give a fuller sound, whilst the Avant Premier Plus speakers are a newer design.
I would be grateful to know whether anybody has experienced both systems or in particular the 902-based combination (the Premier Pluss have been positively reported on). Thanks.
