Mordaunt-Short Avant 908 Wiring
Discussion in 'Home Cinema Speakers' started by pjroyal, May 18, 2005.
  1. pjroyal
    pjroyal
    Aug 16, 2004
    7
    I am thinking of upgrading my fronts to MS 908's which include the sub woofer. I've had a look at the online manual but am confused about how the subs should be wired.
    If I take the sub Woofer line out from my Marantz 5200 amp to one of the speakers does it also have a line out to connect to the other front?
    Have both speakers got a line out so I could connect to my existing sub as well?
    Any views on these speakers would be appreciated.
  2. Beobloke
    Beobloke
    Aug 10, 2004
    1,312
    Out in the Sticks!
    +65
    The Avant 908 does NOT have a subwoofer built in and the only inputs on them are the conventional 2 pairs of binding posts to allow for bi-wiring.
    They are best thought of as 3 way speakers where the 10" bass driver just happens to be on the side of the cabinet, so for an A/V system you will still need a separate subwoofer.
    The only MS speakers that can be wired as you suggest are the THX series 502's. These have a side firing 10" driver that is powered by it's own 150W amplifier and is a proper subwoofer. There are 2 pairs of terminals for inputs to the main drivers plus a subwoofer line in on the amplifier and a line out to the second speaker, which also has another line out so you can run your current sub as well, if you really want 3 subs!! :eek:
    Hope this helps!
  3. pjroyal
    pjroyal
    Aug 16, 2004
    7
    Thanks for the clarification Beobloke. I'll rethink my upgrade options.
