Mordaunt-Short Avant 905 centre
Discussion in 'Home Cinema Speakers' started by MS-Yam, Oct 3, 2004.
  1. MS-Yam
    MS-Yam
    Aug 12, 2004
    240
    16
    Finally, after much skimping and saving, i've got together my full Avant 5.1 speaker package consisting of 906 fronts, 905 centre and 902 rears. :thumbsup:
    I am over the moon having upgraded from the satellite premiere package, which dont get wrong are great, but I now have a much more powerful sound with a nice full midrange.
    My only slight concern is with the centre speaker. It sounds perfect until I turn the volume quite loud i.e. anything past -40db. It has a very full sound which shows no signs of weakness at all, but at this sort of volume and beyond, dialogue tends to be a little overwhelming, perhaps slightly 'boomy'.
    Now, I think one of the main reasons for this is my room is quite small, only around 4m square. What I am wondering is whether anybody else here has the same centre speaker, and what your thoughts are about it. I have to say though it is 100% better than the 304 centre from the premiere package. That was the opposite, it lacked midrange, which was very noticeable when the volume was turned low (dialogue was a struggle to hear sometimes).
    I may try altering the settings on my amp (Yamaha 640SE), maybe lowering the output of the centre channel.
    Let me know your thoughts guys :smashin:
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    I have a 905 but not the Avant version. My room is a little smaller than yours and I don't notice any difference regardless of the volume. Regularly watch DVD's at -30db and there is no difference in clarity compared to, say -50db. It could either be a connection problem or a setting on your amp. If it's any help, I have my speaker set at -4.5db on a Pioneer D912 amp.
  3. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I would say -40 is not loud at all ,have you set the levels up correctly(using a slp meter).I normally listen to dvd's at -25 wich is loud enough for my small room.Have you got the speaker set to small that may help.
  4. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    Forgot to add that I have mine set to large but that's only because I don't have a sub.
  5. MS-Yam
    MS-Yam
    Aug 12, 2004
    240
    16
    Thanks for the replies guys, I will try changing the settings on my amp, cheers.
