MORDAUNT SHORT ALUMNI 5.1 vs Q ACOUSTICS 1010i 5.1 vs CANTON CD102
Discussion in 'Home Cinema Speakers' started by ignorantshed, Feb 12, 2009.
  1. ignorantshed
    ignorantshed
    Feb 23, 2008
    11
    3
    this is going to be my first home cinema setup, ok so i've got my denon-avr1909 and have decided to up my speaker budget to £450, i've narrowed it down to three packages above but have only heard the MS alumni's (which did sound amazing), i'm after anyone else's reccomendations on choosing out of the three
    thanks all
  2. musicville
    musicville
    Feb 6, 2009
    322
    york
    +37
    hi there im thinking the same and am in the same situation as yourself, ie first home cinema setup leaning towards 1010i's as i prefer the styling, currently have a pioneer krl37 which i got last week (and love btw) and im thinking about seeing what the pioneer 1019 amp is like when it is realeased in april to go with them any help opionions etc etc would be greatly appreciated thanks in advance guys
  3. johny1980
    johny1980
    Aug 30, 2006
    2,453
    83
    Aberdeen
    +338
    im waiting for the 1019 to drop a bit and see some reviews but its my fav choice
    i will also need speakers
    had considered the q acoustics but the monitor audio hd's have caught my eye and would match the pioneer styling ( i have a 5090 plasma)
  4. musicville
    musicville
    Feb 6, 2009
    322
    york
    +37
    The monitor audio hd's are great however take a look at the monitor audio vector 5.1 series they are supposed to have a better sound than the Qacoustics and are about the same cost. Exceptional-AV.co.uk : : Specialists in Onkyo's award winning Hifi and home theatre systems
    Alternativly the monitor audio R90 5.1 system can be picked up at some places for £895 which when you consider the subalone sells for £700 ish makes it a bargin! http://www.vickers-hifi.co.uk/retail/radius.html hope this helps :thumbsup:
