MOrdaunt SHort 900i series (908i in particular) discontinued ? If so, what instead ?
Discussion in 'Home Cinema Speakers' started by Graham27, Apr 29, 2007.
  1. Graham27
    Graham27
    Sep 26, 2003
    3,128
    St. Helier, Jersey
    +976
    Hi folks, (please excuse dodgy caps in title, sticky shift key !)
    I was just about to order a set of MS 908i, but I see they're being listed on Richer Sounds website as "last few to clear". I'm curious as to why, does anyone know ? Are they changing that model, or indeed, the whole range ?
    I'd need to rethink my plans if so, as I don't want to end up with a 2.0 pair I can't get the other 3.1 later for.
    I've had a lengthy battle with the guv'nor (which she won, as usual) as I wanted 908i's or MA BR5, RS5 or RS6. She said no to the lot of them initially but then agreed on the 908's. She particularly liked the MS908i's looks, and "sleekness" of drive units, as they've no visible fixings ! Women ! :rolleyes: But anyway, I do really like MS products and I was pretty happy with the compromise.
    So basically, anyone does know what's happening with the 900 series, or have an opinion on a suitable non-MA alternative ?
    If it HAS to be MA that'll involve bribery, and most likely shoes and handbags. If these have to be bought it'll push my PS3 plans back a bit :D
    All advice welcomed,
    Ta much :thumbsup:
  2. OV3RCLOCK3R
    OV3RCLOCK3R
    Aug 26, 2006
    293
    Manchester | UK
    +20
    Dont think their discountinued.
    Also, go for the 908i, i've got the older 908's and there fantastic!
  3. Graham27
    Graham27
    Sep 26, 2003
    3,128
    St. Helier, Jersey
    +976
    Cheers for the info :)
    What makes you think they're not discontinued ?
