Mordaunt Short 500s
Discussion in 'Home Cinema Speakers' started by Dougie Styles, Sep 3, 2003.
  1. Dougie Styles
    Dougie Styles
    I was looking at the Mordaunt Short 500 THX speaker package and I see the left and right fronts have built in powered subwoofers.
    Does this mean there would be no need for a seperate sub? Would you connect them using the sub out or just speaker wire? If you did use a seperate sub would it be very difficult to integrate?
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    You can connect either way, but the general idea is you can use them as the dedicated sub channel.
