Mordaunt Short 500 THX Package
Discussion in 'Home Cinema Speakers' started by mutley, Feb 2, 2003.
  1. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    Does anyone have this speakers?
    Do they need a sub or not?
    I'm looking at this system if a sub is not need (think the fronts have i already!)
    It will be this system or the B&W (603, 601, LCR600) + rel Q150.
    But the mordaunt short center may fit the top of the Sony 44px2...
    And the rears don' t need stands... think the two system are at the same price!
    Anyone?
  2. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    Personally I believe the sub is the most important speaker in movies and that's where the funds should go, I'd get a better sub and spend a bit less on the speakers. You don't NEED THX speakers for movies, that's why Paradigm reference speakers (non-THX) won the best movie package in the USA and they beat M&K who are the THX kings. Just my opinion of course............
    Phil
  3. EvilMudge
    EvilMudge
    The MS THX package is nice, but needs a lot of patience to get the subs in the front speakers to work. The rears in this set do need to be wall mounted or else they don't work at all (you could stick them on the mother of all speaker stands but it's a little excessive)
    The B&W package is also very good. If anything downgrade the rears to 600s and look at other subwoofers than the Q150.
    Have to agree with Phil though, subwoofers are very important, and Paradigm Ref really are rather good :smoke: , if a little on the difficult side to acquire.;)
