agw_01
I was looking on eBay over the weekend and found a pair of new MS302's. They were at £33 with 4 hours left, and finished at £72. I've been looking on this forum and found many good posts about the 302's, so I'm quite interested in them (like the look aswell).
From what I understand, the 902's are THX-spec'd
Is that the only difference between the two models, or will the 902's sound a lot better than the 302's? Can anyone tell me if the 302's are worth £70 (£100 from RS) or should I wait a bit longer and save up for the 902's?
They will be used as fronts for a while, until I can afford some new fronts (probably MS904's). This will be my first step in upgrading my whole system, so I want to make the right choice.
Thanks for any help.
