Mordaunt Short 300M Mounting brackets...
Discussion in 'Home Cinema Speakers' started by ab1385, Jan 14, 2005.
  1. ab1385
    ab1385
    May 30, 2004
    1,279
    Cardiff
    +75
    Not sure if this was the right place to post, but I thought I'd be more likely to get a response here...
    Anyway, I was thinking of changing my rears to the MS Premier 302 satellites, but the problem is that the listening position is back up against the wall the speakers need to be mounted on. Ideally I'd like the speakers to be pointed at each other and slightly down. Do the mounting brackets allow for that kind of angle? How much side to side and up and down movements do they allow?
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,793
    2
    +3,146
    There is a ball joint that allows for that sort of adjusment. From memory it is about 30 degrees in any direction.
