mordaunt genie
Discussion in 'Home Cinema Speakers' started by strontiumdog, Apr 1, 2005.
  1. strontiumdog
    strontiumdog
    ive just ordered some mordaunt genie speakers,what i want to know is can i use any speaker stand that has a universal bracket or do i have to use genie stands.
  2. adrianl
    adrianl
    Pretty sure you have to use Genie stands because of the ball and socket joint integrated into speaker body, and the way stalk from this fits into Genie stand once you remove the base..
  3. strontiumdog
    strontiumdog
    thanks, i will have to look into more carefully,thing is i have a chance to get the atacama stands for free ,would be an shame to pay out for genie stands.
  4. Beobloke
    Beobloke
    Aug 10, 2004
    1,312
    Out in the Sticks!
    +65
    You could actually just sit the Genies straight onto the Atacama stands using their combined stand/wall bracket, but they'd probably look a bit strange!
