mordant short genie 'sub' power failure
Discussion in 'Home Cinema Buying & Building' started by stooman, Apr 28, 2007.
  1. stooman
    stooman
    Good morning!
    I have no power to the sub on my Mordant Short genie system - i've tried all the obvious things...checked cable, fuse etc but looks pretty dead!
    Anyone out there had similar issue and been able to resolve?
    many thanks!
  2. John
    John
    Dec 13, 2002
    11,633
    +3,304
    Welcome to the forums , try a search in the Speakers forum . IIRC there was a spate of failures a few years ago to do with the fuse in the sub and not the plug fuse . I could be mistaken though .
    Your also more likely to find a guy in there called Ed Selley , who used to work for MS (may still do) .
    Good luck in sorting
    Maybe if a mod looks in they'll move this for you ;)
    John
