mooltipicture
J
jonnyseale
toshiba 37wlt58 lcd
samsung le26r41b
infocus screenplay 4805
Hello all, i am looking for a way to get a picture to the above 3 units; fom a yamaha s2500 dvd player. Anyone have any ideas as this is driving me crazy.:mad: thanks.
12 promises
you need to clarify as to whether you wish to send the signal to all 3 at the same time.
there may be a way to daisy-chain or you may need a special multi-distribution box which you should find at maplins or keene electronics.:)
you could also use a video sender with extra receivers.
