Monstercable converter
Discussion in 'Projectors, Screens & Video Processors' started by Punce, Mar 27, 2002.
  1. Punce
    Punce
    Feb 5, 2002
    407
    The Shire, Wales
    +16
    Check this link out
    Has anybody tried this out?
    Sounds excellent - with this you can connect most, if not all, of your devices into your AV switching amp (composite or S-Video) then plug both outputs into this BOX, you can also plug your component DVD player in to the BOX too. It then apparently converts and improves the signal and outputs it in either DB15 RGB or compnent!
    Sounds ideal to keep things simple, if it's any good that is...
    What are your thoughts?
    Mark
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    I've seen the Entech s-video switching device. Used to drive long s-video lengths. It worked well. So they probably know what they are up to....
    Gordon
