im having problems with my setting up my hdtv to my pc.
i have a toshiba 32wlt68 and an xfx 7800GTX EE GPU.
the problem is that i cant get dualview to work using the hdmi dvi cable. i can get it to work using a vga dvi cable into the d-sub at the back of the tv.
there seems to be more resolution settings for the d-sub connection than there is for the hdmi.
does anybody know if the hdmi ports are different in the back of the tosh 32wlt68? using different ones seems to give different results.
thanks for your help in advance
