Monster carbons issue
Discussion in 'Computer Peripherals & Consumables' started by thedude, Jan 28, 2014.
  1. thedude
    thedude
    Oct 18, 2004
    10,162
    Swindon
    +2,070
    My headset is great it sounds amazing but the issue is with the feedback I get from the mic. It buzzes and makes some terrible noise. It's not the headset as it's fine on the ps4 it's just the pc. I've updated the drivers and tried with usb and with the usb and 3.5mm jack.
    Any ideas?
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,940
    Norfolk
    +2,549
    Have you tested in different applications as well?
    You say it's feedback, I take it that means it changes if you move the microphone? Does it vanish if you mute the sound output on your PC (i.e. record then unmute then play back)?
  3. thedude
    thedude
    Oct 18, 2004
    10,162
    Swindon
    +2,070
    I can't hear it my end unless I'm on the audio properties or I decide to stick it on listen. I run a podcast thing and it picks this high whing noise up (not.my.voice) on the podcast
    Also in bf4 it's terrible
  4. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,940
    Norfolk
    +2,549
    Hmm, if it's not being broadcast to your headset or speakers it can't be feedback.
    Do you have any other microphones on the system (built into the screen etc.)? You could try selecting that particular input to record from rather than everything.
    Some motherboards do have ropey microphone inputs, but if you can put it through USB then it's arriving as digital data and wouldn't be affected this way.
  5. thedude
    thedude
    Oct 18, 2004
    10,162
    Swindon
    +2,070
    The mic is via usb
