Monster cable & PAL 60 ???
Discussion in 'Xbox Forums' started by quimpy, Mar 21, 2006.
  1. quimpy
    quimpy
    Jun 24, 2005
    85
    I've read on other thread that you have to switch your HD cable to normal TV then set the screen format to PAL 60 then flick your cable back to HD and it works. Mines a Monster cable and it doesn't as far as I'm aware have this sliding switch:mad: Does anybody know of any other way to get PAL 60 on a HDTV.
  2. MonkeyKnuckle
    MonkeyKnuckle
    Dec 8, 2005
    6,519
    Portsmouth
    +718
    i switched the cable to the composite cable, luckily mine is set up in a way so i can easily get to the composite connections on the tv and the back of the console
  3. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,159
    Bristol
    +9,898
    Go back to the cable that came with your pack and use that to select PAL60hz.
    If you got rid of it then you are pretty much stuck unless you know someone with the MS Composite or Component cable.
