Thanks for that but after something that will elevate the already good looks![]()
ok thanks, thats a great price.ended up paying £160 for gloss black including the port. I did collect it though.
Such said:much cheaper than buying a new M+
The missus likes it so much that I jested with her that I would get another to replace a coffee table ....... and she agreed
So now I have a project - to turn my cherry veneered cabinet into gloss black and then buy the parts and rebuild it.
Any suggestions to help with the gloss black conversion is much appreciated.
thanks
Send it to a car body repairer!! It's difficult to get a gloss black finish![]()
Such said:cheers for that, do i need to do any prep first, like smoothing and any idea how much they would charge?
thanks
Do what I was going to do with it and get it painted by a car body shop. My m8 was going to do it for £40.
I wouldn't do any prep, in all honesty, your more likely to cause work for the repairer, unless you specifically know what you're doing.
I would imagine, if there's not much damage to fill and smooth, you would be looking at roughly £140 ish. Bear in mind it would likely need about 1/2 litre of paint and about 1/2 litre of laquer too. That's roughly £70 materials. Obviously, get a few quotes first.
Think I'll do that then, so no sanding required then?
Also, do i need to use the same driver that BK use? I will get their standard mono amp and perhaps their driver, but not sure of the cost as its not listed on the website
thanks
