Mono block suggestion help please
Discussion in 'AV Receivers & Amplifiers' started by BLACK_MAGIC, Sep 7, 2003.
  1. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    604
    manchester
    The set up i have currentley at the moment is:
    kef 203's driven by a chord spm 1200c (mains)
    kef 202c biamped with a musical fidelity a3.2 power amp (centre)
    Kef 201's driven by a chord spm 600 (rears)
    My brother wants the mf a3.2 power amp which im going to give him after I find a suitable replacement.
    Ive decided I want (for now) to go for a reasonable quality mono block to drive the centre. I would have loved a chord mono block but it seems they dont actually make one:(. Its a shame because the sound that chord makes with the kef's imo is probably about as best as it gets (with my budget).
    I would like to spend no more really then £1500, but like I said I would like a good mono block. I was wondering if any of you could suggest maybe 1 or 2 that are worth auditioning that are atleast up to chords standard and similar in sound (if possible).
    I would also rather a mono block that is still in production.
    Thanks to all those that help.
  2. EvilMudge
    EvilMudge
    You're currently biamping your centre, why not get a stereo Chord and continue biamping? Or is cost too much of an issue in that case (Chord always = very expensive in my book)?
  3. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    604
    manchester
    I could biamp with another chord spm 600 but the cheapest I could get that would be for £1850. I just dont think its really worth spending the extra biamping the centre. If i can save a bit by going with a good mono block i will:) I was hoping that the sound quality of a £1500 mono block would be close to biamping with a £1850 amp. Also if the mono retails at around £1500 i would probably get it for around £1200 (from my local hifi dealer) giving me a saving of of over £600 which i should really start thinking about buying food with for the wife and kid. They have been kinda neglected in the last few months:)
  4. Gambit
    Gambit
    The new Cyrus Mono X will be around that price point (maybe a little less) and is a nice little runner, though I'd imagine the sound would be different to Chord (I've never heard Chord amps so can't comment on them). I'd imagine a London dealer somewhere would carry both brands and could give you some help BM.
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Stick with the Chord amps you have,and maybe look at buying an extra one for the centre channel,possibly a used or ex-dem model.
    IMHO,the Chords are definitely better than the Cyrus amps.
    There's also the issue of different sound qualities between amps to consider,although you have been using an MF power amp for the centre.
  6. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    Chord DOES make mono blocks! Model #s are SPM 1400E and SPM 6000. Both are VERY expensive though...
  7. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    I would (if you cannot go Chord) try for second hand Musical fidelty 300 or 308 stereo power amps or a Tag 250mr.
    Regards
    Steven.
  8. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Good point,Steve...the Tags are being offloaded by some dealers who got a bit worried about Tag's long term review(Sevenoaks HiFi I think had a few)....it's an OK pwer amp,nothing special,but better than their earlier offerings....not in the Chord league though.
  9. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    For the record Arcam is introducing the P1 monoblock power amplifier at the end of this month. It is based on the P7 topology and is a further step forward - it is clearly an outstandingly transparent and powerful amplifier. Retail price in the UK is expected to be £1099.
    HTH,
    John Dawson (Arcam)
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I would stick with Chord here, don't ruin it for a sake of a few pounds
  11. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    604
    manchester
    Looks like the best option is really gonna have to be going for another chord spm600 for the centre.
    Its just getting harder and harder trying to justify it all to the missus. Funnily enough there doesn't seem to be any problem when shoe and handbag shopping comes up as a unnecessary expense:(
