Mono and Sub
Discussion in 'TAG McLaren Audio Owners' Forum' started by Bogi, Oct 26, 2004.
  1. Bogi
    Bogi
    Oct 12, 2003
    403
    28
    Sweden
    +27
    If I play a mono track on my AV32R DP unit and the crossover is 80Hz will the sub take care of the low stuff?
    I mean it's not like Direct, Direct+Sub or Stereo. Just plain Mono.
  2. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    If L/R are set to full range and centre is bass limited then the bass will go to L/R.
    If L/R are set to bass limited and centre is bass limited then the bass will go to the sub.
  3. Bogi
    Bogi
    Oct 12, 2003
    403
    28
    Sweden
    +27
    Thnx!
    As always, all I needed... :thumbsup:
  4. kraal
    kraal
    Aug 23, 2004
    103
    Portugal
    I have the xover at 50Hz and I have the same efect. Under 50Hz go to the sub.
