Pandora
Hello.
I've purchased a Dayton Audio BST-1 High Power Pro Tactile Bass Shaker 50 Watts 4 ohms
It has a frequency response of 10-80 Hz. I am going to use to create a vibration test plate which should vibrate in this frequency range.
Please can anyone recommend a suitable low-cost amplifier which will provide a mono output as low as 10Hz? It will ideally operate off 240VAC or 12VDC.
This one purports to have a frequency response down to 3Hz:
Velleman VM100 200W Power Amplifier MODULE | Quasar Electronics UK
This one looks ok for spec but is a bit expensive
https://www.amazon.co.uk/auna-C500-2-Amplifier-2-Channel-Power/dp/B0787D8N6Y
Budget is up to £60. Thanks for your help - I'm an audio novice.
— As an Amazon Associate, AVForums earns from qualifying purchases —
