Question Monitor with standard Sky HD box
Discussion in 'Satellite TV, Sky TV & FreeSat' started by yugobob, Nov 2, 2017.
  1. yugobob
    yugobob
    Apr 9, 2017
    4
    Brighton
    Hi.
    Just wondering if a monitor like this would work plug and play (via HDMI cable) with a sky HD box.
    https://www.amazon.co.uk/Dell-28-in...846031,p_n_feature_ten_browse-bin:12855887031
    If so how would a standard HD picture look on it scaled to 4k res. I know some old SD programs look terrible on a HD screen, would this have the same problem.
    Also assuming it would work fine with a game console such as ps4 or xbox (or the pro or x)
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,570
    Redditch
    +4,192
    The monitor has a HD resolution (Not 4K). It will handle 2160P but downscale to 1080p.
    Screen Resolution 1925 x 1080 pixels
    Maximum Display Resolution 3840x2160
    You need to check it will sync at 50Hz (PC's use 60Hz or higher).
  3. mccg
    mccg
    Jan 9, 2006
    121
    +16
    As Graham says - you need to check if it supports 50fps.
    I have 2 older Dell monitors - neither will work at 50fps - only "US" rates (23/24/30/59/60 fps).
