Monitor outs on Yamaha RXV650
Discussion in 'AV Receivers & Amplifiers' started by MacReady, Feb 26, 2005.
Tags:
  1. MacReady
    MacReady
    Jun 25, 2003
    2,599
    3
    Dewsbury, West Yorkshire
    +246
    I have only been using my Yam 650 for about a week now and it is the first time I have used any amp I have had for AV switching...and I am getting a bit confused about something.
    I have my DVD player and XBox going into the amp via componant cables and my Sky+ and Laserdisc player via S-Video cables. I then have the Componant out going to my Sanyo Z3 projector and the SVideo out to my Tosh RP TV....the problem I am having is how do I get pictures from my Sky+ and LD player to my Projector ? The amp dosn't seem to be able to pass the signal from the S-Video inputs through the componant output (this is where someone tells me I should have bought the 750 as it can do this probably..lol).
    Do I need an S-Video switching box or something so I can have two outputs to both the TV and projector (which would be far from ideal as I forgot to run an S-Video cable to my Projector which would mean the pulling up of floorboards again)
    Any help appreciated.
  2. nealgs
    nealgs
    you have a number of ways - but the 650 AFAIA doesn't do video up-conversion like the 750(?) or 1400/2400/2500 etc do (i.e. converts S-Video to Component etc).
    you could get a component switcher like a Zektor HDS4.2 which does 4 component inputs with 2 outputs (1 for plasma, one for projector or whatever)
    SKY+ box if got a SCART passthru on it could be fed to JSTech RGB2YUV converter which could then be fed to another input on Component switcher etc
    Only problem with this solution is cost :(
    JSTech RGB2YUV about £150
    HDS4.2 about £400
    Maybe buying an amp with 3 component inputs could be cheaper - sell 650 and use money from it to fund suitable model??
    Gary
  3. MacReady
    MacReady
    Jun 25, 2003
    2,599
    3
    +246
    Thanks for the reply Gary. I have only just got the amp so dont really want to think about replacing it just yet.
    I am not desperate to watch Laserdiscs on the PJ as I think the quality will be a bit of a turn off....but I would like to be able to watch stuff from Sky+ on it so may have to think about getting the picture from the Sky box to the projector via the componant cable.
    I can't believe I didn't get an S Video cable installed at the same time as the componant one but it is too late now :(
  4. ciarancummins
    ciarancummins
    Mar 9, 2005
    87
    Dublin
    I believe you can use 1 component cable as a composite cable. Therefore, plug the red cable at both ends of your component cable to the composite in:pJ out:650 and down convert your s-video connections. Have not tried it myself, but I believe it will work for those times you want to view it, and then change it back..... a pain I know, but ar least it is something...
    let me know how you get on.
    Ciaran
