Monitor fault or software problem
Discussion in 'Desktop & Laptop Computers Forum' started by freddyuk, Aug 3, 2006.
  1. freddyuk
    freddyuk
    Sep 27, 2004
    216
    My Dell monitor has developed a series of thin green parrallel lines down the left hand side of the screen and there appears to be some other colour distortion.
    Is this likely to be the monitor packing up or maybe a software problem?
    Any ideas please?
  2. stevec46
    stevec46
    Nov 24, 2005
    192
    +3
    Is it a CRT (older style Big \ deep ) monitor or LCD?
    Could you borrow monitor to see if it is monitor or PC, could also be Graphics in PC.
    Can you describe distortion?
    Steve
  3. freddyuk
    freddyuk
    Sep 27, 2004
    216
    Its a new ish LCD and best i can describe is thin green parellel lines, say 6 lines down the left hand side of the screen.On pictures there is also some green line distortion where the lines run across the picture . These are basically scanning lines thickness if that makes sense.
  4. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,371
    Have you got the correct drivers installed for the monitor and graphics card? If so, call Dell right now and get a replacement.
