Monitor Cable help please
Discussion in 'PC Gaming & Rigs' started by Bobz, Sep 24, 2004.
  1. Bobz
    Bobz
    Sep 23, 2004
    11
    I have an LG Flatron F900P CRT monitor ( http://www.elara.ie/products/detailsfullat.asp?productcode=ECE751395&productID=55838 ) and want to upgrade the cable used to connect it to my graphics card - Sapphire Radeon 9600XT Atlantis 256M DDR AGP ( https://www.komplett.ie/k/ki.asp?sku=121421 )
    My monitor has BNC connections but is it a vga or an svga monitor?
    I am looking for a good BNC lead but am unsure which type i need.
    Do i need a "HDDB15 Male>5BNC Male" like this cable: http://www.elara.ie/products/detailsfull.asp?productcode=ECE618403&productID=40453 ??
    I would be greatful if anyone could tell me if this is the cable i need or if they could direct me to a high quality cable that would suit my needs.
  2. mjn
    mjn
    May 24, 2001
    22,946
    Herts, England
    +11,094
    vga = 640x480
    svga = 800x600
    so i doubt your monitor is either!
    But the cable you've got listed sounds like the right one. 15 pin male to 5 BNC.
  3. Bobz
    Bobz
    Sep 23, 2004
    11
    Thanks for clearing that up mjn!
    Going to look around for one of those cables now.
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    you can buy this cable for £5.40 on ebay.co.uk
    I just did (and that includes delivery)
